Well, I went through the tutorial on battery replacement at 720/730 920/930 Battery Replacement Tutorial and seemingly succeeded when I turned it on again. And then I touched the screen. Nothing. It doesn't recognize me anymore. (I will presume I am not dead, as I look nothing like Bruce Willis and Hayley Joel Osment is not in the room seeing dead people.)
So, apart from the obvious answer (you screwed up dude, take it apart again and be more careful this time, yeah, I know, I know...), any suggestions on likely places in the reassembly where I did such screw up? My suspicion is the flex cable didn't get put in too well, since it was kind of a pain to get reseated, although the fact that the display LOOKS perfectly normal (until it gets to the 'agree' push button I need to press to get it going again) might suggest the flex is not the problem.
Ideas?
Ideas?
