Hi everybody
Has anybody bought an XL Live within the past month or so & have it reset during use for no reason? I have.
Just a short story just incase somebody else has had the same problem.
The unit was only 2 weeks old before this issue began. I would set up a route and before it even told me where to go it resets itself.
After 4 days of this I contacted TT support who when through the default script. Do a 'hard reset', make sure the unit is updated, do a complete reformat.
In the end I had them send me an RMA. Sent the unit back on a monday and had it back the following thursday with a note saying there was no fault found.
Lucky me....
Although I did make sure to note down a few details from the unit prior to return.
Comparing the details as shown in the 'Version Information' I found out not only had they downgraded the software on the unit but they installed the Western_and_Central_Europe_2GB map when I only had the United_kingdom_and_Republic_of_Ireland map.
So after doing another software upgrade I have found that there was another update to the unit which so far has not made the unit reset. This is the first day i've been able to check the units operation.
Unfortunately I am unable to reload the Western map as my unit does not have enough space to store it on, although HOME does say that it will shrink it and allow me to select certain sections of the map for me to use, but it did not work.
I will update this post if after a week the unit is faultless or if I have to return it again.
Pre return info
App 9.054.531676.2, OS 515773
(1024, 26/5/2010)
64 MB RAM (free: 26.4 MB)
GPS v1.20, Boot 5.5138
Map: 'United_kingdom_and_Republic_of_Ireland' v855.2884
Language: English UK
Post return info
App 8.420 (1258/091116) OS:344822
64 MB RAM (free:17.2 MB)
Map: 'Western_and_Central_Europe_2GB' v845.2645
Post return Update info
App 9.058.568435.2, OS 541764
(1030, 25/8/2010)
64 MB RAM (free: 27.0 MB)
Map: 'United_Kingdom_and_Republic_of_Ireland' v855.2884
Lucky me....
Pre return info
(1024, 26/5/2010)
Post return info
(1030, 25/8/2010)
