i cant access the device..i dont know if i did this wrong, when i first launch tomtom at my pc it asks me to update some files, i also update the latest map, i tried to install it but it says it has no free space, so i deleted the old map ( i made a back-up for the map ) and tried to install the new map, so when i try to add a new map it says the map cant be used in the device untill its activated first
btw when i tried to add a map the file size is around 1.7 gb ( old map?), and the new map i download is around 1.6 gb, but when i add, only map appears is the 1.7 gb which is the old map right?
it gives me an error it says "problem with map, you cannot use this map on this device, usa_canada_mexico_p-165"
