Just thought I'd let everyone know that the TomTom USB cables are standard mini-USB cables.
Same data cable as my Motorola Razr - confirmed working.
Same thing goes for the car charger... standard USB output is 5 volts and the power connections are USB standard.
Also Walmart has one for about $8 online. I remember buying one in the store for a similar price when I needed a data cable for the Razr.
http://www.walmart.com/catalog/product.do?product_id=5065132
"So what", you say. "I can order one for only $10 from TomTom." Maybe you've lost yours or you're on the road without one and you want it now.
I know it says PSP, it's ok... a standard USB cable with a mini connector... it will work on your TomTom as well as your Motorola Razr.
Maybe you already have a spare mini-USB cable lying around... now you know it will also work on your TomTom.
