Hello,
Have a brand new XXL540 TM (5" model) and all I can say is Wow ! First gps I've ever had.
Sure I'm going to have a lot of questions, and really glad for this Forum. Would like to ask this, please:
Also bought a TomTom Universal Air Vent Mount Kit.
Seems to be well made, but-
With the curved back of the 540, and with the ring in the middle (which protrudes another 1/8" or so even after removing the ball-mount components that pop-off)), the top and bottom fingers of the mount barely encompass the unit; fingers (the ends of) are right at the end of the 540.
The 540 certainly doesn't "snuggle" against the flat back of the mount, like it probably should.
Not a very secure grasp of the fingers, and does not inspire confidence.
Am I missing something ?
Any thoughts on this would be most appreciated.
Hate to return it, as it seems very well made.
Also, seems to be no way to rotate the plane of the unit. Seems to only have lateral x & y adjustments. Is there some angular orientation(s) possible ?
Are there other dashboard vent mounts that perhaps do a
better job of securing a 540 ? Suggestions ?
Much thanks,
Bob
Much thanks,
Bob
