My regular computer which I've been using to update GPS quick fix and map share files died, so I installed Tom Tom Home on another computer (XP Home, same as dead computer).
I connected my XL340S and it said I needed to update the application, quickfix GPS and mapshare files. I clicked ok.
Then...
So no other files could be uploaded. I disconnected Tom Tom, closed the Home program, restarted the computer and tried again.
This time... "can not create F:\data.chk"
Disconnected and reconnected Tom Tom again. It searched for needed updates, snd started the process, then...
error writing f:\tthome.bif
and then
can not create f:\ephem
Now when I turn on my Tom Tom I get the screen showing a picture of the Tom Tom and a big flashing red circle with an "X".
How can I fix?
I do have the oriiginal backup on an external hard drive.
Then...
and then
How can I fix?
