TomTom Start 2 Help
Hi, I'm new to the forum and have tried searching but all the information is slightly confusing.
My problem is that when planning a route with the TomTom Start 2 I can't find a way to preview the route in text form in a list like I can on the TomTom ONE, it just shows it on the map so you can't tell what roads its going to go down. Is there a simple way to make this possible?
Welcome to TTF.
I'm afraid with that model which comes with 'EasyMenu', there are significantly fewer user preferences, including the option to view route as text -- as you've discovered.
if you look at sticky section it tells you how to do it, i got exactly same prob with a tom tom start but it my parents, so havent tried it yet.
Thanks, I followed the information in the sticky and it turned out to be a simple process. Works well now and can view the route in text form.
