Tomtom Rider 2 Audio
ALH
Canada
I got a TomTom Rider 2 from a friend that is all there except the Blue tooth headset. What is the least expensive way of getting the audio on my bike? Is there an Audio speaker built in? Can it be wired into the radio on my 2009 H-D Road Glide so it can come thru my speakers? Can I hard wire a earphone cord to my helmet or is the Scala Rider blue tooth my only (rather expensive) option? Thanks
Recommend you find any headset that works for you that supports the Bluetooth A2DP profile. That's what the Rider expects. There are, I am sure, units available that aren't as expensive as the Scala.
