My daughter bought me a remote for my GO730. She did her research and the 4M02.000 shows several places as being compatible with the GO730. It does, in fact, operate the GPS fine...for a few key activations.
I originally picked up a 4-pack of Energizer Alyline batteries for the remote. I loaded the first pair in, fired up the TomTom and bingo, all worked fine. The remote appeared to "go to sleep" when I laid it down after diddling with its functions for a few minutes. I probable pressed the keys 30 or 40 times, max. After a couple of hours I came back to the car, fired up Tom and tried to use the remote. It would not come on. So I popped out the batteries and installed the second pair. The remote started up fine and operated the TomTom fine.
The remote sits more than it gets used and I think that is probably typical. Don't you know that darned remote would not come on after a few hours sitting idle. I removed the second set of batteries, took them and the origina pair in the house and checked them with my battery tester. All four were drained about 2/3.
So...I went out and bought s 4-pack of Energizer rechargeables. I already had AA rechargable and the charger I had for those accepted AAA's as well. I charged them over night and popped a pair in the remote. It worked fine...for a couple of hours. They drained just like the normal batteries. Same thing with the second set of rechargeables.
What gives here?
AND...I have attempted to concact TomTom three darned times via their website on this remote. Do you think those people will reply over and above the auto-reply thanking me for contacting them and promising someone would be back with me. What a joke their support function (dis-function) of their website is!
To be fair, I have not tried to call yet. That is my next step and I don't think I will be real pleasant when I finally get through to someone.
Comments on TomTom support?
Thanks in advance for your input!
What gives here?
