Hi,
I have a tomtom one 2nd edition that kept saying no maps found, now i have two problems, firstly the unit is stuck on hungarian language, have tried reset using pin and no joy, the second is i have formatted hard drive and used totom clear flash tool, after i sort out language problem can i just copy map back on to unit ? or do i have to use tomtom home, as tomtom home does not give option to install map from computer to device.
Thanks in advance
Thanks in advance
