- Joined
- Jul 18, 2010
- Messages
- 62
- Location
- Newcastle-on-Tyne UK
- TomTom Model(s)
- One (30 Series)/125/130 (512 MB) and XXL Classic - 2GB TTS
Sometimes I go a couple of weeks between using my satnav and when I switch it on I get the "drive safely" page then the "this device belongs to" page. When I press continue quite often that's as far as as I get and only by holding down the off switch till I get the tomtom logo and the sound then the unit resets its self.
I have a nagging feeling that when I made the original windows backup I unplugged the unit before the program was fully downloaded though I have updated the unit several times since I bought it and have always made a windows backup of the update.
It works fine when its running, its only when it has been standing for a while I have any problems. When I use it in the car I always plug it in so it is fully charged when I put it away.
It could be the battery just slowly goes flat or the unit needs a fully charged battery to work properly.
I believe rechargeable batteries slowly go flat even when not in use. Joe
