Problem: No satellites detected in standalone mode, remote control with Home works fine.
I just got my TTNE, loaded Home, the software ran a bunch of updates, along with 7.162.
When I restarted after the update, the system gave me the Bad SD card graphic. I hit the reset and tried again, with no luck.
I thought I had a good backup, but was wrong.
I copied all my data off the SD, and tried a file check under Windows. That finished, but didn't make a difference. It did recover some bad data though, and put it in the file0000 folder.
I started searching the forum, and found the archive from OldMan with an earlier version. I copied these files to the root of the SD, and the system would boot, but not find any satellites. Although Home would work fine while on remote control.
I started copying the same files from my archive, that were in the OldMan .zip, and found that I needed his DATA.CHK and TTSYSTEM files in order to get the system to boot, but the rest of my original files were copied back to the SD with no apparent effect on the system.
Since it would boot, I connected with Home and took a backup, so I could feel free to try the 7.162 upgrade again. This time it went off without a hitch, but it still will not pick up any satellites in stand alone mode.
Also, I get one color of map, grey, no matter what I choose...
Any help would be greatly appreciated....
Thanks in advance,
Tim
Thanks in advance,
Tim
