Now a new problem. My drive tells me to add a device. When I try, nothing happens.
I have reset, removed my drive and , reinstalled and still nothing.
I cannot find the tomtom in the list of devices so I cannot update or remove it because there is no driver.
I did not explain correctly
I cannot see my device. I do not see a driver for tomtom in the device manager, so my drive says add a device. I do not want to add another device, I just to see my go supreme, and I cannot.
To clarify even further, MyDrive IS the driver for your device. It is what turns the USB connection into a TCP connection, allowing the device to act as a tiny mini-server.
Here's something I'd like for you to try. Hope I remember it correctly ...
Using your favorite browser and with your TomTom connected and MyDrive running (at least in the background), use this address: http://169.254.255.1/personal/
See if the device responds. If not, we need to look at the USB side of the connection.
