- Joined
- Mar 28, 2009
- Messages
- 4
This thread may not be in the right place, but I could find nowhere that seemed better. Please move it if the is a more appropriate spot.
I recently got a used TomTom One and like it quite a bit-
fast, accurate and easy to use.
(I do have experience with Garmin and computer nav software as well.)
But I do have an issue:
I don't use Windows.
TomTom Home does run fine (using wine) in linux but it will not connect to the device.
I can easily mount the unit and look at everything on there, so the issue is not USB or anything physical.
wine automatically creates a link to the device as a card reader, so wine can see the device.
My suspicion is that TomTom Home is looking for either a device with a specific NAME or it needs a windows registry entry to access the device.
Since I don't really USE windows, this causes a problem for me.
What I am looking for, if possible, is any Windows Registry info concerning the hardware itself- device name, connection string, the key name and data type and so on.
Basically the full Registry info for a TomTom One, preferably in Windows XP and most likely somewhere in Hardware.
I can add Windows Registry entries in wine to my hearts content, but I have no idea what data to enter.
I could be completely wrong and this may not fix the issue at all, but I would like to try, so if anybody can, I would be grateful for help.
Be warned though- just go into the Windows Registry can be dangerous and anyone who is NOT aware of the risks should probably not even try.
(Warning added in case somebody doesn't know! I'd hate to think somebody trying to help ME broke their os...)
