Ok, so I found a TomTom S- Edition that is imported on Walmart. I need to know if it has an SD card slot or any other kind of slot and it's specifications, like RAM, features. I already tried google.
http://www.walmart.com/catalog/product.do?product_id=10782293#Specifications
That's the link, please help!
Cross-posting = bad
Enclosure Color: Silver
Plug and Go: Works straight out of the box
Latest and most complete maps pre-installed in its internal memory
Door-to-door navigation anywhere in USA and Canada
GPS Receiver Technology: High sensitivity GPS chipset
Display Type: 3.5 inch full TFT color LCD touchscreen
Display Resolution: 320 x 240
Text-to-Speech
Touch Screen: Yes
Input Method: Touchscreen
Processor: CPU 266 MHz
RAM Installed: 32MB
Device Interface: Bluetooth Interface
Battery Type: Built-in lithium ion battery
Battery Life: Up to 2 Hours
Specifications
Weight: 2.1
Display Size: 3.5" screen
Display Pixels: 320 x 240
Battery Life: Internal Litium-Ion battery (2 hours operation)
Dimensions: 3.8 x 1.0 x 3.2
Model: ONE-S Edition
Key Features: Bluetooth Interface
Model No.: ONE-S
Shipping Weight (in pounds): 2.1
Product in Inches (L x W x H): 3.8 x 1.0 x 3.2
Assembled in Country of Origin: Imported
Origin of Components: Imported
