Tomtom Go Expert Plus not charging
Go Expert 7"
Anyone any ideas?
I've tried 3 different cigarette lighter ports but absolutely nothing, no red light on the charger.
Anyone??
Is it the cable?
Have you tried with another cable?
Maybe a problem with the mount.
Have you tried plugging the cable directly into the GPS?
Is it the cable?
Thanks for the reply.
Cable looks ok, splits/nicks etc
I've tried with a normal usb cable that charges my phone directly to the unit and that does work BUT I have no USB sockets in the truck! only 12v cig lighters!
Mount is fine I think.
I did unscrew the end of the charger to reveal a fuse, could that be the issue?
GO Expert comes with a cigarette lighter charger.
Are you using this charger?
Have you tested the outlet on the truck?
In a TomTom charger there is no fuse.
In the truck, however, there is a fuse.
Oh ok, what is the the small glass looking thing in the end of the cigarette lighter charger the bit unscrews at the end, looks like a fuse to me but ive no idea.
In my opinion, if the light on 3 cigarette lighter sockets does not come on, either your truck fuse is dead.
Have you tested this truck socket output with other equipment or asked a colleague to plug in his GPS to test?
Khaled
