TomTom 910 - I need mount part number
TomTom has a problem with the mounts initially and they upgraded them.
The first batch of mounts would sag and have connectivity problems.
They came out with a new mount which solved the problems.
Last year they sent out replacement mounts to people that had the old mounts.
The way to differentiate the mounts was that the first batch had only Lock and Unlock icons while the second batch had three icons - Lock, Unlock and some EYE icon.
I just heard about the replacement program - but I stopped using the mount last year and just used velcro in the car. now I would like to get the new mount but I need to provide Tom Tom with a Part Number that is provided on the old mount.
Can anyone give me the part number off their 910 mount unit?
Thanks in advance.
I think the # was on the bag. If it was on the mount I'll have to look at it when I get home. I dont use my mount anymore :)
Which mount do you use instead of the original mount?
How do you get power to the unit since on mine there is no power plug directly into unit but through the mount
Reido
