TomTom 1005 - weird problem
UK
Hi, I'd appreciate any guidance on this please - just started happening:
The unit accepts the destination when entered, and moves to show the route summary - but when it should start, it seems to freeze - with the location signal staying stationary and the speed indicator showing 0mph.
It is not the whole unit that's frozen, though - you can re-enter another destination (or re-enter the one just programmed) and all appears OK up to the route summary, then repeats as above.
Many thanks
Rob
Try a drum reset on the unit by holding the power button about 20 seconds till you hear the drum sounds
If you don't have a destination planned, does the chevron move along your regular path, with normal speeds shown? Or does this only happen with a route planned?
Moot now since it's behaving properly with route planned (good!). But thanks anyway.
Peter2471
