I'm trying to get the device code so I can get my activation code to be able to download the US/Canada maps. The only problem is I can't get in the main menu to get the product code because it says 'No Maps Found'.
Map activation is handled via TomTom Home with the newer maps, if you have a rather old map then you can find the device code by connecting to the computer use Windows Explorer to open the drive letter associated with your device. Locate the file "ttgo.bif" right click it and select Open With/ NotePad, your device code will be one of the line items - Mike
