Tom Tom 1 - How do i input GPS co-ordinates
Reg
Hi,
Just joined this forum.
I have a Tom Tom 1, there is a facility to input Longitude and Latitude co-ordinates but more camp sites are putting their GPS co-ordinates on their web sites, can I use GPS on the Tom Tom and if so how ?
Regards
Reg
If you wish to add the points as items in a custom poi category you wish to create (such as 'my_campgrounds') you would create the category and then add poi-->lat/long position and then give that location a name.
Similar process if you wish to add the locations as favourites.
You can 'Navigate to' the point indicated by the coordinates.
Select 'Navigate to', go to the next page and select 'Latitude Longitude'.
