TT IQ Live
I've just had my first continental trip with my TT - albeit on a coach trip to Brittany.
Every night I charged the TT from the mains using an adaptor. Sometimes the battery symbol would change from a lightning flash to a green battery, but usually it didn't - voltage too low, possibly?
In either event, I'd follow parts of the route on the coach next day; I was able to do this for about a maximum of an hour in total, before I got the "battery low" message,
Is this normal - a full battery won't last even an hour?
I'd switch the TT off on the long motorway sections, switching it on in cities. However, usually it wouldn't be able to find the new position. Eventually it would reset itself - screen went blank, TT screen and music note (I had sound off), and it would then show my "home" area. After a few minutes, it would go to the actual position.
Is this the sort of behaviour you'd expect?
The unit behaved very well apart from that, though obviously the coach sometimes went a different route, whereupon the TT would smoothly and quickly replan.
