Technical
Go 6000
Can anyone advise if it's possible, and how to, import Google maps files to a Go 6000?
Unclear what you mean by "Google maps files".
If you're asking whether actual Google map data can be used on a 6000, the answer is definitively no.
But are you instead asking whether personal points of interest you have added to a Google map ("My Maps" data) can be moved to and used on a 6000?
Thanks. I understood you could as As Google map files are KTM and convertible to GTX but as I can find no reference to this you must be correct.
PJPH
