Superior vs max
<img src="/styles/default/custom/flags/no.png" alt="Norway" /> Norway
Hello,
I need help deciding between the TomTom Superior or Max. Which one offers better features? I'll mostly use it for the car, but occasionally for a caravan, although that's very rare.
In your opinion, which one should I choose?
Hi
If you want to tow a caravan from time to time, you might as well get the Camper Max or the Exclusive.
With the Superior for towing a caravan you just have to plan the routes you want to take.
Thanks for your comment 😊
I will ask
If someone has tried both, please leave a short comment about the experience in terms of the speed of finding a new route and also the driving experience.
RvdH
