Greetings, forumites
I currently have a 340S, and it's served me faithfully over 3 years.
My commute has drastically changed and now takes me through the heart of two counties with mad traffic. I need something with realtime traffic.
I've narrowed my choices to the 1505 and 2535 with Lifetime Maps and Traffic and have questions that I've not been able to answer through a day of googling, lookign at tomtom.com and searching this forum, and would like your input to help me decide:
Thanks in advance for your input,
V'ger
- For both the 1505 and 2535, (Lifetime Maps and Traffic) do these use cellphone for traffic updates, or are they the old-style RDS?
- Is there a cost for HD traffic? If so, what is it? WOuld it be worth it over the "normal" traffic info?
- The GUI in the 340 could be set so the page is "sideways" -- the navigation info and controls along the side, instead of the bottom. I prefer it on the side. Can the new units still do that?
- The 340 speaker is a piece of work, it's loud, clear, no distortion. How do the speakers in the 1505 and 2535 compare?
- Same question for the mount -- the 340 mount is superb, if cup and glass are squeaky clean, they simply won't part until you say they do. How effective are the new mounts? The last thing I want is a heavy unit crashing into my thin, old, brittle dash.
- And last but not least: The OS speed in the 340 is pitiful. In searching locations, there is a second's or two pause from key press to feedback. Similarly, re-routing after a missed turn on a long route can end up in the re-route taking so long that you miss the next turn as well. How's the 1505 and 2535 handle compared to the 340? Fast and crisp, or like a wet sponge?
V'ger
