Suction Mount
This might be trivial but I can't get the suction mount to stick on my windshield anymore. It worked flawlessly for the first 2-3 weeks that I had the TT 720 but now it is not good. I tried cleaning the window, cleaning the cup, cleaning everything...no luck. Anyone have any ideas what happened? I am at a complete loss for ideas. :confused:
When placing the suction mount on the window, be sure the to push the stem of the mount as close to the windshield as possible. That usually helps the sunction to stick real well.
Stick the mount 1st! Then place the unit. Do not place the unit on the mount then stick it. It will drop!
