Strange thing when deleting a POI
U.S. Pacific Northwest
GO 930T
I followed the usual steps to delete a POI that is not there in the real world, but when I got to the final screen the button options were BACK or DIAL. No sign of a DELETE button. So, I pressed on the DIAL button and the next screen that popped up said "Are you sure you want to delete this POI?"
Any input?
TT 930T
dial button
Any input?
TT 930T
I have the 920 and the same problem occur with the 8.3 and 8.301. Don't expect a fast cure. This problem is probably last under a 50 problem list with the 8.3
Any input?
TT 930T
Just hit "dial". It will do "delete" for you. It is mislabeled, but it works. It's one of a huge laundry list I hit tech support with the day I "upgraded" to 8.300 firmware.
