Let me just explain the situation I find myself in.
My cars cigaret lighter is not working. To use TT-device I charge it via the car stereo usb. The cable I am using is a usb to mini-usb cable. It charges just fine but the problem is that every 3 minutes the device will auto shut because it thinks its connected to a PC and the user is idle when I dont press the touch screen.
So here is my question: Can I charge the TT-device via a cable with USB on one end and RDS TMC connector on the TT-device? Is there a cable of that sort? And where can I find it?
I have googled like crazy with no luck.
I use a TT GO730.
Would be grateful for a reply that would help me out.
Regards
I use a TT GO730.
Regards
