Speed Changes don't Take
Carson, VA
GO 2535
Are we unable to change speed limits on Interstates? I have tried several times to change a speed limit on a short section of I95 but it doesn't make it to the Go 730. I tried making the changes using Home and on the Device. I have tried doing the hard reset but nothing works. I have made changes to speed zones on local roads with no problems but I cannot get this change made to I95. If anyone else would like to try, it is the section of I95 just south of Petersburg, VA between the I95/I295 intersection north past the next 2 exits to the railroad tracks. The speed limit has recently changed from 55 to 65. :confused::mad:
I was able to change the speed on my 720 and the route demo worked fine.
It's a really hard road to change. If you select it for a speed change it changes hundreds of miles of I-95. This is because the change speed limit (and change road name) selector will choose the entire stretch of road that has the same name.
You have to choose a sidestreet in the area, then in the next screen say "edit", and deselect the sidestreet and choose I-95. I-95 is cut into a number of smaller segments, so you have to make sure they are all selected (turned green) before tapping done.
MDB
