Speed Camera Cost
Go6200
I’m trying to decide between the Go Superior and the Go Navigator. The difference that would impact me, is the length of speed camera updates. If I choose the Navigator, what is the cost of speed camera updates for the second year?
Thank you. It’s a no-brainer then. The Navigator is £70 cheaper and the second year of speed cameras only costs £35.
The cheaper alternative is, don't buy the speed camera update and don't exceed the speed limit.
Okay, tone down the rhetoric, both of you please.
I’ve simply asked about the price of a service offered by TomTom and I receive a condescending response that in no way provided an answer to my question.
Sorry if you took offence. My reply was in no way intended to be lecturing or condescending. It was just intended to be a frivolous comment.
Over the years I have spent many hours and have made dozens of contributions to this forum in an attempt to solve TomTom problems and also help others with issues that I have also experienced.
Now having been counselled by a Moderator, I will probably think twice before contributing to this forum again.
mysspotif
