For anyone else who has been having problems with XULrunner.ext crashes:
These happen during a Map Share update. The update is seen, and then downloaded, but Home will crash when it tries to copy the new files to the unit (720). I went back and forth last month with tech support. They weren't able to figure it out and I ended up returning the unit for a new one. That was fine until Oct. 5. I had been getting daily updates. Then on that date the update failed and I got the old xulrunner.exe error. Then I stopped receiving map share updates. I thought, "well, maybe there aren't any updates today." Unfortunately, it continued like that for days. I could receive and install GPS fixes and POI update, but no map updates. I tried uninstalling Home and cleaning the registry. That didn't work, despite trying several times, even with the special registry cleaning file provided by tech support.
I decided that it sounded like a corrupted file on the device itself. I didn't have my backup with me here at the office. So I looked at the files structure on the 720. I found several files that looked like they were from the last time the maps updated. They were all related to maps, so I thought they'd be a good bet.
-So I started the update
-it found new updates
-I paused and went to the device and moved the suspect files to the recycle bin.
-I went back to Home and elected to download/install the updates.
-They installed just fine
Probably only one of the files was corrupt. I haven't played any further to determine the culprit. But listed below are the files:
CurrentMap.dat
UserPatch.dat
newsettings.dat
ttgo.bif
Good luck and good night
CurrentMap.dat
UserPatch.dat
newsettings.dat
ttgo.bif
