- Joined
- May 14, 2010
- Messages
- 1
So I have a minor issue on my TT One XL... Almost every time, or every other time I go to start the gps it simply won't start. I have to do a soft reset, and then it comes on just fine.
I have tried just about everything I can think of... When I contacted Tomtom about this, they recommended removing the application and reinstalling it. I did that.
I've tried the clear flash utility multiple times (each time following the 3x procedure).
I also tried reformatting the internal drive, connecting the unit to HOME and letting it install the application again, and then installing my map again from a backup.
This issue has been frustrating me for a while, and I thought I could sit down and solve it. However, I have spent hours searching the internet and trying different solutions. At this point, I'm just about ready to give up and accept the fact that I need to live with a bent paperclip always at hand if I want to start up the gps . Unless someone here has an idea? I noticed in the process of reformatting the internal memory that, even with a completely formatted drive, I would still experience this glitch... Reset > start > shutdown > sometimes another start, or sometimes a reset needed. Maybe this is a hardware issue?
Here's the info on the unit:
Tomtom One XL-S
App 8.010
USA & Canada map v710.1575
Thanks in advance for any advice!
Tomtom One XL-S
App 8.010
