Still playing with the new Go510, and came up with an odd situation.
I find that it I travel to a destination, I can add it to my favourites.. but only if I am on the road. Like, I stop on the street and add to favs (using GPS coords), and it says I am at 123 Main Street (or whatever), then I have the option to enter a nickname for the location.. like Mike's House. And that works fine.
However, if I travel to a destination like a shopping mall or community center with a large parking lot, enter the lot, park, and then try to add to favs (again, using the GPS coords option), it shows a question mark as the location; I type in Costco (or whatever parking lot I am in), and it saves the location in the favs.
However, the problem is with the latter, the stored fav is useless. If I am back at home, and navigate the Costco, it says it cannot find the route.
It appears that if I store a fav using a GPS location for a spot that is not directly on a street, it cannot be used later.
Has anyone experienced this? Is there a way around this, other than going back out the the street at the entrance to the facility and entering the fav from there?
