I have a new go expert 6 which I use as a coach driver. I can plan the routes using the online Tom Tom planner and they sync perfectly with the device. The issue is when using the nav on the route at random points within the route the screen will go black then come back within a few seconds. It’s at random and random intervals of times. Sometimes it appears again in a few seconds sometimes it takes 20 seconds. When it reappears it will then look at whole route again and give me a new eta. The nav works perfectly with no issues when just using one destination just an issue when using a “route”.
Anyone had a similar issue or knows a fix ?
Thought it was faulty to start with but because it works fine on normal navigation it can’t be. I have tried a factory reset and the device has connectivity and is up to date.
Thanks in advance.
Thanks in advance.
