Screen blanking Go Camper Max
Go Camper Max
Once on a journey the screen blanks for anything from 5 to 10 seconds when transitioning between the localised screen for a junction and returning the normal journey screen.
When it does return it shows the entire journey screen, repeats the destination arrival time before going back to the journey screen with the correct road position.
This has resulted in missing some turns as it blanks at the time a turn is needed.
I have thought of resetting the device. But unsure whether it will correct the fault.
Today over WiFi it did an update.
The application version is 25.100.0002 - 06/02/2025.
What to do?
Are you using the car charger that came with your GPS?
Resetting your GPS can sometimes resolve the problem.
Paul Devall
