After using the Rider and ScalaRider Q1 several times without issue, the headset and GPS won't connect. I started having this problem on the way home from a trip when I realized the Q1 was no longer announcing directions and the GPS said "headset not connected". Both units were fully charged. I entered pairing mode on both devices, the GPS asked "do you want to connect to ScalaRider Q1?", then it said "some features are not supported" and went back to the pairing screen. The Q1continues to flash red and blue as if it's in pairing mode until it times out after 2 minutes then goes into standby mode. The headset pairs just fine with my phone, so I don't think that's the issue but I could be wrong.
