Rider 550 starts routing on its own
Rider 550
Twice now my Rider 550 has started routing on its own out of nowhere from the map screen. Anyone else seen this behavior?
I have a similar problem, every time my TT starts it’s routed to HOME. If I’m out for a ride and stop and turn the key off the TT goes into sleep mode and when I restart the bike it loads HOME as a destination, I then have to go through the menu and cancel the present route.
Any ideas!
Any ideas!
Have you tried the suggestion in the post just above yours?
Hi all, I was here looking for an answer same as your problem above, when Im out for a ride and turn off the bike when I switch back on it always routes me to home, as Im away alot this is so annoying BUT the answers above seem to have sorted my problem out so Thank You for that. Well it seems to be sorted here at my desk, once Ive tried it on the bike I will let you know. Thanks again.
Hi all, Just an update all tested and now all cured Thank You guys.
ScouserJoe
