Rider 550 Keeps restarting/freezing
<img src="/styles/default/custom/flags/lv.png" alt="Latvia" /> Latvia
Rider 550
Hi!
Tom Tom Rider 550 restarts every 2-3 min?
Is it fixeble?
Thanks!
Hi
Parameter then Tomtom service deactivate Mydrive synchronization on the device reactivate you to transfer a course.
@alon69
If I may help a little translating the above:
There has been a recent problem reported where a device reboots constantly due to issues when making connection to the TomTom cloud. If you will go into the setup and select "Stop syncing" or whatever that translates to in Latvian, see if that stops the rebooting.
I have had to do this for a while now. I turn on syncing to the cloud long enough to get any information I have set up, and then I turn off syncing so that I don't keep having reboots.
Ja varu mazliet palīdzēt iepriekš minētā tulkošanā:
Nesen tika ziņots par problēmu, kurā ierīce turpina restartēties, jo rodas problēmas, izveidojot savienojumu ar TomTom mākoni. Ja ieejiet iestatījumos un izvēlaties "Pārtraukt sinhronizāciju" vai ko tas latviski nozīmē, pārbaudiet, vai tas neaptur pārstartēšanu.
Man jau kādu laiku tas ir jādara. Es ieslēdzu mākoņa sinhronizāciju pietiekami ilgi, lai iegūtu visu iestatīto informāciju, un pēc tam izslēdzu sinhronizāciju, lai izvairītos no atsāknēšanas.
Thank you for your advice. I'll try this and see what happens next.
However, I have also had problems with synchronization with cloud lately :( But this will be the next question.
sueb123
