- Joined
- Mar 17, 2023
- Messages
- 3
- Country
- TomTom Model(s)
- RIDER550 & RIDER410
I have had a problem which so far has not been able to be resolved and the Tomtom official forums wasn't any help. Tomtom want me to send the unit off to Romania BUT I would rather get it fixed here in the UK, if I am able too.
The issue - I believe a corrupted map file is stopping the tomtom unit from loading past the initial splashscreen. The loading bar goes across the bottom & then hangs up not far from the end. It stays on the splashscreen. If I connect to mydrive connect it will just spin the circle of nothingness and not connect the unit, if I go to reset the unit it will just do nothing and keep resetting itself ie USB on / USB off but not actually completing what it is meant to be doing therefore just loops like the circle of nothingness. It shows me I have 0mb of space on the internal memory, I am also able to see there is a corrupted map file as well as the other map files etc I have in the internal memory but will not let me actually delete!
If I could just get into the internal memory - I would be able to delete the corrupted files...
or if I could just reset the unit....that simple!
