Rider 4xx/5xx battery replacement
<img src="/styles/default/custom/flags/de.png" alt="Germany" /> Germany
Rider 550
Hi, I need to replace the Battery on a Rider. I found some information about the used battery, something like VF3W type.
Can someone recommend or give a link to order this battery?
I am able to replace myself.
Hi
There has been a lot of feedback that the Rider 550 battery is nowhere to be found on the web.
the only solution is to ask Tomtom to change the battery for you.
Hi, I am not sure if the 4xx series has the same battery as the 5xx series. I opened my Rider 550 and checked for the type. (see yourself).
If you google for VF3W battery or battery NCA903864A you will find a lot of replacements and below 20€.
I think this should help!
Are you sure your battery is dead?
Have you tried charging your rider via a smartphone mains charger.
I know this is an old thread but regarding battery replacement, Tomtom will only replace under warranty. The after sales care is non- existent
even if your rider 400 is no longer under warranty Tomtom can still repair it for you
virleiafm
