- Joined
- Oct 29, 2016
- Messages
- 2
- Country
- TomTom Model(s)
- go720
I have just put a replacement battery in my GO 720 but it doesn't appear to be getting charged as it immediately turns off when removed from a power source. Exactly the same thing happened with the battery that I removed (original) although that did seem to remain on briefly.
Is there something else that could be the problem? I have since bought a new "6 GO 620
but still want to use the old device in another vehicle as it works perfectly well apart from the battery not holding a charge. The on screen indicator shows that it is charging.
