- Joined
- Apr 17, 2025
- Messages
- 1
- Country
- TomTom Model(s)
- Carminat TomTom Live
I just got a 2012 Megane and I ejected the card to try updating it.
TomTom Home detected the card and I made a backup file and then tried to update it. No updates were available so I put it back in the car and it got stuck in a boot loop of a Renault TomTom splash screen and then an hourglass.
The card now is no longer detected as a device by TTH and Windows tells me there are issues with the card itself. I took a new SD card and used TTH to restore the backup I had previously made. This new card allows the in-car device to boot up properly but now I get the error message that the device "You cannot use this map on this device".
TL
R - Renault Carminat SD card corrupted. New card made from backup won't allow me to use the same map file.
TL
