After trying a few headsets (owned and other) I realize that there are quite a few pitfalls when it comes
to buying a headset which works well with the Rider satnav/s, and supports all functionality.
Unfortunately - here again - the user manual is of very little help.
My requirements (all high priority) are
- stable BT connection
- volume can be changed from the Rider menu (no phone needed, no app needed, no fuss)
- connects with AND without A2DP, whatever needs to be selected in the Rider setup (here too, no fuss)
- high quality ANC
- small enough to fit under a helmet
- they can be used for other applications, e.g. TV (meaning low latency)
I have been looking at Amazon of course, but this won't tell me whether a product works with the Rider.
Does anybody have a recommendation ?
- high quality ANC
