Today I went to CC and they had a 720 next to a 730. I wanted to check a route to see how the two would compare. I used a starting point of Huntsville, Al and a destination of Wichita, KS. The 730 chose a very good route. See pic below. The 720 with 7.05 maps chose to go up to St. Louis, then west to Wichita, not a good route. Both routes were chosen to NOT avoid toll roads.
A couple of days ago I asked a member who has a 720 with 7.20 maps to check this route. He also got the same route as the 720 in CC.
This leads me to believe that there is something up with IQ routing. If the 7.20 maps and the 8.05 maps use the same data, then it has to be software that is making the routing selection. Thus a x20 and x30 with the same type of map data do not work the same.
I'd like to get a third party to verify this on a x20 with 7.20 maps. Can I get someone to prepare a route, using Huntsville, Al as the starting point and Wichita, KS as the end point. DO NOT avoid toll roads. It should route you via St. Louis.
Is anyone running hacked V8 code with 7.XX maps on a x20 that could check this too. That would be the most definitive test.
