I am having a problem with TTH on a Mac running OS X Snow Leopard 10.6.3
Version = 2.7.3.754
Language = en-GB
* Computer info:
Operating system: Mac OS X 10.6.3 Intel
* HOME info:
DLL Version: 2.7.3.754
MapShare DLL Version: 2.7.3.754
Language: en-GB
I complete destroyed my TT G720T with thsi and as I had laid out a lot of money on maps I went ahead and boughta Go 550 Live. thinking I could use these maps on there but alas I have been proven wrong. (this is for another post.
On following the instructions of TT Help desk I now am using a Micro SD card now when I try to eject the Device I start to get loads and loads of errors. Before uing the SD card no issues.
When I had this problem before TT Help desk did admit there is a problem with TTH and Mac OS x Snow Leopard. See snippet from Help desk.
Dear X,
Thank you for contacting TomTom Customer Care
The reference number for your query is 091029-011377.
Following investigation by our 2nd line technical department, there is currently an issue with MAC and the the latest version of the operating system (10.6 Snow Leopard) + HOME 2.7 + a TomTom device with both internal and SD memory. This has been reported to the software developers team.
Please can you remove the SD card and try to update the device, does this make any difference? Should you wish to download updates and want to have some of the updates on the SD card then it is possible to copy them manually to the SD card - to do this please make sure there is enough space on the internal memory , otherwise you will get a message that you have to use an additional card.
I apologise for any inconvenience caused.
With Kind Regards
Sophia
The TomTom Customer Care Team
Should you wish to reply to this email, please log in to your TomTom account via TomTom, portable GPS car navigation systems.
Click on ?My TomTom? in the top right -> ?My Questions History', click on 091029-011377 then scroll down to the bottom and click on 'Update Question'.
You can also attach documents that you wish to send to us by clicking on 'Browse'. You can then find the document you wish to attach and click on 'Add Attachment'.
Alternatively, you can call us on one of the numbers below:
United Kingdom 08451610009 Mon - Fri: 9:00 a.m. to 6:30 p.m. GMT
Republic of Ireland 1890812008 Mon - Fri: 9:00 a.m. to 6:30 p.m. GMT
South Africa 800980670 Mon - Fri: 9:00 to 19:30 CET
Our contact details are on TomTom, portable GPS car navigation systems - Support home - Select your product
Response (Sophia D. (UK))
Has any one else have this issue?
Version = 2.7.3.754
Language = en-GB
* Computer info:
* HOME info:
Language: en-GB
Dear X,
With Kind Regards
Sophia
