I’m new to this forum and hope someone can help me out. I just purchased a RDS-TMC receiver to go with my TomTom XL S IQ Routes GPS. The GPS acknowledges the receiver when it’s connected and puts up the traffic bar on the right side of the screen. My problem is it doesn’t seem to be able to pick up any stations despite the fact that Total Traffic Network indicated there are 6 within my receiving area. I know for certain I get within 10 miles of one transmitter during my commute. I’ve tried the usual things like selecting the factory default settings, a soft reset, and even manually setting the frequency, none of which worked. I even stopped at a rest center on the highway for 10 minutes or so and pulled the GPS with receiver outside the car to make sure it wasn’t attenuating the signal. Still no reception. All I get is the car icon with an arrow circling around it, never a green dot. In all cases when I was trying this out I had a route programmed in. Initially I assumed the problem was a bad receiver so I returned it to the store and got a replacement unit. Same problem! Am I doing something wrong?? Was there a bad batch of receivers manufactured by TomTom? Do I have the right model number receiver?
Here’s the list of my equipment and software:
GPS - XL S IQ Routes Model 4EM0.001.02 (serial number starts with RU)
Application software – 9.510.1234792.2
Map – United_States_2GB V915.5074
TomTom Home – version 2.9.7.3256
I also checked for corrupted files on the TomTom. None were found.
The RDS-TMC receiver and charging cable in question is model number 4UUC.001.01. Based on the information from TomTom’s website it should be compatible with my GPS.
The GPS works great but this receiver is starting to give me headaches. I would appreciate any help in getting this to work Thanks in advance for any suggestions.
