Brand new member - I hope someone can help where tom tom support cannot!
I have a new PC running Windows 7 - 64
tom tom support advise me that something is stopping Home from connecting to their server and have said they have no idea and now I need some help!
Home runs OK and when I attach tom tom GO 720 TT Home seems to talk to it as it comes up with GO 720 connected at the bottom right.
As soon as I click update my Go I get the searching for updates screen with the loading bar in the middle - and that is it it sits there for as long as you leave it.
I can see the Tom Tom in windows explorer as drive I: and can see all the directories etc
Based on this Tom Tom Support said that Home is connecting to my Tom Tom correctly but is not able to connedt to the Tom Tom Server for some reason - and said they couldn't help any further. They could be correct re no server connection as I can select backup in TT Home and it works OK - but I am a bit upset that tom tom support can't offer any help!
I have Norton Internet Security and have turned off smart firewall, intrusion prevention and just about everything else that can be turned off and it still doesn't work
Any ideas what to try next or look for that could be causing this problem?
PS all works fine on my work XP PC - however this is being upgraded in a couple of weeks and I would like to sort out the problem before I have no way of doing updates to my tom tom at all!
John
John
