Problem with Garmin 920T (Voices)
Can you record more than one personalized voice on the TomTom 920T. I was playing around with my voice and it only uses my recorded voice. i tried recording my daughter's voice but there is no option to do so, I will need to delete my voice and put my daughter's voice, such a headache.
Just offering a guess...
I don't know the answer, but I will offer a guess. When you record your voice, the TomTom applies a certain file name to it. Record your daughter's voice and the TomTom uses the same file name overwriting yours. I believe the other voices have unique file names. Try recording your voice, identify the file, rename it, record your daughter's, and then see if it all works.
