When I try to place a custom POI from this site on my TomTom, it seems to send it into a rebooting loop (I'll get the outline of a navigation screen, but it will be all blue and never lock onto the satellite or show a map, then it'll reboot itself). Downloading the free Baskin Robbins and Dunkin Donuts POIs provided from the TomTom Plus site worked fine. But with other ones, nothing seems to work... I tried adding a bunch of Redlight Camera POIs, and then only the Redlight LA POI. I even tried renaming the latter, figuring that maybe it would like Redlight_Los_Angeles.bmp better than Redlight LA 1.3.bmp.
I even tried doing this just using the TomTom as a USB device, not launching TomTom HOME at all (since my TomTom seems to have trouble every time I use HOME).
But in all cases, the 910 kept freezing and going wacky until I removed the Custom POI files again.
Have any of you experienced this? Any idea what I might be doing wrong or how to fix it?
