Just want to start by saying I found the various 'Menu customizing' threads in here really useful. Thanks everyone!
Now, I have a weird problem when I switch between my custom menu and the default TT menu ....maybe someone has experienced this as well.
I have a TT1 V.3 and I add a custom menu with a button on both the default and the custom menus to change back and forth, if I so desired. I found that there was a need to do this from time to time. Now I found that I have to goto the default menu because my custom menu doesn't have the 'Set safety preferences' on it. Here's the problem:
I don't care for the annoying warning that is set to go off everytime you drive above the speed limit set on certain roads/freeways by TomTom. So, after finding out on here that I could turn this setting off in the 'Set Safety preferences', I went ahead and switched back to default menu and turned this setting off. Then I switched back to the custom menu I use and I figured that was it. I was wrong. I still get the warning for some weird reason and when I switched menus, the warning was back on again in 'Safety preferences'! So, my question now is two-fold:
1) Does it the 'Warn when driving above speed limit' get reset whenever I switch menus or something?
2) Is it possible to add the 'Set safety preferences' icon to my custom menu? I tried to do this in the 'TomTom Menu Designer' by Greg Duncan, but I can't find the icon for it in the list and I don't know how to get it from the default menu into my custom one.
Would be very grateful for anyone's help on this. Thanks!
Toledospod
Toledospod
