When I was using 7.221 and 7.481 I had everything installed on the SD card in my 720 and the internal memory completely empty and it worked great. When I upgraded to 8.010 if I install everything on the SD card the unit locks up at the TomTom opening screen. If I install the program on the internal memory and the maps on the SD card the unit boots but then tells me no maps found. Now if I install a map on the internal memory with the program then it'll find it plus the ones on the SD card. Funny huh??
1) Anyone else have this issue or am I the only one that wants to put everything on the SD card???
2) Anybody know if TT did this on purpose?
3) Should I just get over it and put an old map on the internal memory with the program and live with it?
